Samsung Chromebook 4 Plus XE350XBA-K05US Device Hinge Replacement
  1. Samsung Chromebook 4 Plus XE350XBA-K05US Device Hinge Replacement, Screen: step 1, image 1 of 2 Samsung Chromebook 4 Plus XE350XBA-K05US Device Hinge Replacement, Screen: step 1, image 2 of 2
    • Face hinge side towards you
    • Unscrew three 4.55mm Philips #000 screws (pointed by the arrow heads) from the each of left and right hinges
    • Pull out the black film connected to the motherboard in the white slot
  2. Samsung Chromebook 4 Plus XE350XBA-K05US Device Hinge Replacement: step 2, image 1 of 2 Samsung Chromebook 4 Plus XE350XBA-K05US Device Hinge Replacement: step 2, image 2 of 2
    • Open up chromebook hold onto the hinges as you open to make it easier
    • Separate the keyboard and screen and put the keyboard off to the side
    • Use the ifixit opening tool to pop the outer edge of the scree up
  3. Samsung Chromebook 4 Plus XE350XBA-K05US Device Hinge Replacement: step 3, image 1 of 2 Samsung Chromebook 4 Plus XE350XBA-K05US Device Hinge Replacement: step 3, image 2 of 2
    • Remove the four 3mm Phillips #000 screws
    • Lift the screen up slowly
    • Find the black wire on the back and lift the metal clamp
    • Pull the black film to remove the wire
  4. Samsung Chromebook 4 Plus XE350XBA-K05US Device Hinge Replacement, Hinge: step 4, image 1 of 1
    • Remove the three 2.8 mm screws marked by arrows from both the left and right hinges
    • Lift the hinges
0 Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 7
All Time: 89
