Samsung Chromebook 3 XE500C13-K02US Display Hinges Replacement
  1. Samsung Chromebook 3 XE500C13-K02US Display Hinges Replacement, Display Hinges: step 1, image 1 of 2 Samsung Chromebook 3 XE500C13-K02US Display Hinges Replacement, Display Hinges: step 1, image 2 of 2
    • Place the laptop back cover facing up to expose all nine 4.6 mm screws.
    • Remove all nine 4.6 mm screws using a Phillips #00 screwdriver.
  2. Samsung Chromebook 3 XE500C13-K02US Display Hinges Replacement: step 2, image 1 of 2 Samsung Chromebook 3 XE500C13-K02US Display Hinges Replacement: step 2, image 2 of 2
    • Wedge a plastic opening tool underneath the cover of the laptop.
    • Once the tool is wedged between the cover and the body of the laptop, slide the tool around the edge of the laptop to disengage the retaining clips.
    • Remove the cover of the laptop to expose the inside components.
  3. Samsung Chromebook 3 XE500C13-K02US Display Hinges Replacement: step 3, image 1 of 3 Samsung Chromebook 3 XE500C13-K02US Display Hinges Replacement: step 3, image 2 of 3 Samsung Chromebook 3 XE500C13-K02US Display Hinges Replacement: step 3, image 3 of 3
    • Disconnect black and white wire from the I/O board.
    • Remove two 4.6 mm screws from the display hinge using a Phillips #00 screwdriver.
    • Rotate both display hinges upward, away from the components.
  4. Samsung Chromebook 3 XE500C13-K02US Display Hinges Replacement: step 4, image 1 of 2 Samsung Chromebook 3 XE500C13-K02US Display Hinges Replacement: step 4, image 2 of 2
    • Remove the nuts with a 5 mm nut driver socket.
    • Remove all six washers from each side.
  5. Samsung Chromebook 3 XE500C13-K02US Display Hinges Replacement: step 5, image 1 of 1
    • Remove the hinges from the bar on both sides.
Caden Smith
397 Reputation
2 Guides authored
IUPUI, Team 3-3, Harley Spring 2023 Member of IUPUI, Team 3-3, Harley Spring 2023
IUPUI-HARLEY-S23S3G3
4 Members
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 12
All Time: 100
