Samsung Chromebook 3 XE500C13-K02US Battery Replacement
  1. Samsung Chromebook 3 XE500C13-K02US Battery Replacement, Bottom Case: step 1, image 1 of 2 Samsung Chromebook 3 XE500C13-K02US Battery Replacement, Bottom Case: step 1, image 2 of 2
    • Place the laptop back cover facing up to expose the screws.
    • Using a Phillips #00 screwdriver, remove nine 4.6mm screws from the back casing.
  2. Samsung Chromebook 3 XE500C13-K02US Battery Replacement: step 2, image 1 of 2 Samsung Chromebook 3 XE500C13-K02US Battery Replacement: step 2, image 2 of 2
    • Use an iFixit opening tool to wedge in between the case and body of the laptop.
    • Once the tool is wedged in between the case and laptop, slide it around the entire laptop's edge to disengage the retaining clips.
    • You should hear a popping sound as you slide the iFixit opening tool around the laptop.
  3. Samsung Chromebook 3 XE500C13-K02US Battery Replacement: step 3, image 1 of 2 Samsung Chromebook 3 XE500C13-K02US Battery Replacement: step 3, image 2 of 2
    • Remove the cover exposing the inside of the laptop.
  4. Samsung Chromebook 3 XE500C13-K02US Battery Replacement, Battery: step 4, image 1 of 2 Samsung Chromebook 3 XE500C13-K02US Battery Replacement, Battery: step 4, image 2 of 2
    • Remove the four 4.6mm screws with the Phillips #00 screwdriver.
  5. Samsung Chromebook 3 XE500C13-K02US Battery Replacement: step 5, image 1 of 3 Samsung Chromebook 3 XE500C13-K02US Battery Replacement: step 5, image 2 of 3 Samsung Chromebook 3 XE500C13-K02US Battery Replacement: step 5, image 3 of 3
    • Use the spudger to pry underneath the cable and gently lift the connector up.
  6. Samsung Chromebook 3 XE500C13-K02US Battery Replacement: step 6, image 1 of 1
    • Lift the battery up and out of the case.
2 other people completed this guide.
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 19
All Time: 1,532
