Samsung Brightside Logic board Replacement
  1. Samsung Brightside Logic board Replacement, Logic board: step 1, image 1 of 3 Samsung Brightside Logic board Replacement, Logic board: step 1, image 2 of 3 Samsung Brightside Logic board Replacement, Logic board: step 1, image 3 of 3
    • Here is the Samsung SCH-U380 Brightside
    • Turn it over to gain access to the battery.
    • Remove the backcover by simply pulling it off the phone from the top down
  2. Samsung Brightside Logic board Replacement: step 2, image 1 of 3 Samsung Brightside Logic board Replacement: step 2, image 2 of 3 Samsung Brightside Logic board Replacement: step 2, image 3 of 3
    • Remove the battery
    • Remove the six Phillips screws from the back frame
    • All six screws are identical M1.5X3
  3. Samsung Brightside Logic board Replacement: step 3, image 1 of 3 Samsung Brightside Logic board Replacement: step 3, image 2 of 3 Samsung Brightside Logic board Replacement: step 3, image 3 of 3
    • Use a plastic opening tool or similar tool to separate the top from the bottom frame. Applying slight pressure in a downwards direction will disengage the plastic clips
    • Continue to slide the tool along the slot until you feel the plastic locks disengage
    • Once all locks have released, the bottom frame can simply be removed.
  4. Samsung Brightside Logic board Replacement: step 4, image 1 of 3 Samsung Brightside Logic board Replacement: step 4, image 2 of 3 Samsung Brightside Logic board Replacement: step 4, image 3 of 3
    • Remove the two Phillips screws from the EMI shield.
    • Both screws are identical M1.5X2
    • Remove the EMI shield
  5. Samsung Brightside Logic board Replacement: step 5, image 1 of 2 Samsung Brightside Logic board Replacement: step 5, image 2 of 2
    • Detach the LCD connector.
    • Remove the logic board
oldturkey03
785,103 Reputation
119 Guides authored
Global Fixers Member of Global Fixers
Community
33 Members
576 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 19
All Time: 1,532
