Introduction
I noticed that there was not to much information about working on this phone. I received one in a non-working condition and figured it would be a good chance for some guides. The phone is easy to work on and no hidden screws or clips, no excessive glue. A straight forward no nonsense phone.
Here is the Samsung SCH-U380 Brightside.
Turn it over to gain access to the battery.
Remove the backcover by simply pulling it off the phone from the top down
Use a plastic opening tool or similar tool to separate the top from the bottom frame. Applying slight pressure in a downwards direction will disengage the plastic clips
Continue to slide the tool along the slot until you feel the plastic locks disengage
Once all locks have released, the bottom frame can simply be removed.
6 other people completed this guide.
3 Comments
Works great. It is worth mentioning that there is a slight difference in the disassembly between the black and blue models, as it is easier to leave the flex cable in place with the later. However, the the remainder of the information is directly transferable. Thanks for your contribution!
