Samsung ATIV Book 9 Plus Speakers Replacement
  1. Samsung ATIV Book 9 Plus Speakers Replacement, Back Cover: step 1, image 1 of 3 Samsung ATIV Book 9 Plus Speakers Replacement, Back Cover: step 1, image 2 of 3 Samsung ATIV Book 9 Plus Speakers Replacement, Back Cover: step 1, image 3 of 3
    • Turn the laptop upside down so that the underside of the laptop is facing you.
    • Use a Phillips #000 screwdriver to unscrew the 4.3 mm screws located on the edges and corners of the laptop.
  2. Samsung ATIV Book 9 Plus Speakers Replacement: step 2, image 1 of 1
    • Lift the cover to reveal the interior of the laptop.
  3. Samsung ATIV Book 9 Plus Speakers Replacement, Speakers: step 3, image 1 of 2 Samsung ATIV Book 9 Plus Speakers Replacement, Speakers: step 3, image 2 of 2
    • The speakers are black, and form a block-like "L" shape around the bottom half of the battery.
    • Lift from the corners of the speakers to remove them.
  4. Samsung ATIV Book 9 Plus Speakers Replacement: step 4, image 1 of 2 Samsung ATIV Book 9 Plus Speakers Replacement: step 4, image 2 of 2
    • After lifting the body of the speaker out of the laptop, you will notice that the top of the speaker is connected to the laptop by cables.
    • Continue removing the speakers by gently squeezing the sides of the white connector.
  5. Samsung ATIV Book 9 Plus Speakers Replacement: step 5, image 1 of 1
    • Gently tug on the white connector in order to remove the speakers.
Karoline DaVee
136 Reputation
1 Guide authored
Baylor, Team 2-3, Grigsby Spring 2015 Member of Baylor, Team 2-3, Grigsby Spring 2015
BU-GRIGSBY-S15S2G3
4 Members
4 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 13
All Time: 1,493
