Samsung ATIV Book 9 Plus Screen Replacement
  1. Samsung ATIV Book 9 Plus Screen Replacement, Back Cover: step 1, image 1 of 3 Samsung ATIV Book 9 Plus Screen Replacement, Back Cover: step 1, image 2 of 3 Samsung ATIV Book 9 Plus Screen Replacement, Back Cover: step 1, image 3 of 3
    • Turn the laptop upside down so that the underside of the laptop is facing you.
    • Use a Phillips #000 screwdriver to unscrew the 4.3 mm screws located on the edges and corners of the laptop.
  2. Samsung ATIV Book 9 Plus Screen Replacement: step 2, image 1 of 1
    • Lift the cover to reveal the interior of the laptop.
  3. Samsung ATIV Book 9 Plus Screen Replacement, Screen: step 3, image 1 of 1
    • Disconnect the wire connected at the marked location. This is done by giving it a solid tug parallel with the laptop.
  4. Samsung ATIV Book 9 Plus Screen Replacement: step 4, image 1 of 2 Samsung ATIV Book 9 Plus Screen Replacement: step 4, image 2 of 2
    • Unscrew the three 4.3 mm screws by using a #000 screwdriver located on the hinges in both corners of the laptop.
  5. Samsung ATIV Book 9 Plus Screen Replacement: step 5, image 1 of 2 Samsung ATIV Book 9 Plus Screen Replacement: step 5, image 2 of 2
    • Remove the piece of foam that covers two antenna cable connectors.
    • Use the tip of a spudger or a fingernail to pry straight up and disconnect the antenna cable connectors.
  6. Samsung ATIV Book 9 Plus Screen Replacement: step 6, image 1 of 1
    • Now the screen is completely disconnected and can just be lifted off.
Casey Kauffman
329 Reputation
2 Guides authored
IUPUI, Team S6-G6, Baechle Fall 2017 Member of IUPUI, Team S6-G6, Baechle Fall 2017
IUPUI-BAECHLE-F17S6G6
3 Members
3 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 15
All Time: 2,149
