Samsung ATIV Book 9 Plus Keys Replacement
  1. Samsung ATIV Book 9 Plus Keys Replacement, Keys: step 1, image 1 of 2 Samsung ATIV Book 9 Plus Keys Replacement, Keys: step 1, image 2 of 2
    • Open your laptop so your keyboard is facing you and is easily accessible.
  2. Samsung ATIV Book 9 Plus Keys Replacement: step 2, image 1 of 3 Samsung ATIV Book 9 Plus Keys Replacement: step 2, image 2 of 3 Samsung ATIV Book 9 Plus Keys Replacement: step 2, image 3 of 3
    • Using a plastic opening tool, carefully push the thin tip under the key.
  3. Samsung ATIV Book 9 Plus Keys Replacement: step 3, image 1 of 2 Samsung ATIV Book 9 Plus Keys Replacement: step 3, image 2 of 2
    • Pivot the tool upwards. This should pry the key away from the keyboard.
    • Hearing some snapping sounds should be normal as the key lifts away from its attachments.
    • Continue lifting the tool until the key comes away completely or gently pull the key off. Repeat for other keys as needed.
    • Be gentle, as the attachments may accidentally break with rough handling.
3 other people completed this guide.
unknown
261 Reputation
1 Guide authored
Baylor, Team 2-3, Grigsby Spring 2015 Member of Baylor, Team 2-3, Grigsby Spring 2015
BU-GRIGSBY-S15S2G3
4 Members
4 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 18
All Time: 6,150
