Samsung ATIV Book 9 Plus Internal Fans Replacement
  1. Samsung ATIV Book 9 Plus Internal Fans Replacement, Back Cover: step 1, image 1 of 3 Samsung ATIV Book 9 Plus Internal Fans Replacement, Back Cover: step 1, image 2 of 3 Samsung ATIV Book 9 Plus Internal Fans Replacement, Back Cover: step 1, image 3 of 3
    • Turn the laptop upside down so that the underside of the laptop is facing you.
    • Use a Phillips #000 screwdriver to unscrew the 4.3 mm screws located on the edges and corners of the laptop.
  2. Samsung ATIV Book 9 Plus Internal Fans Replacement: step 2, image 1 of 1
    • Lift the cover to reveal the interior of the laptop.
  3. Samsung ATIV Book 9 Plus Internal Fans Replacement, Internal Fans: step 3, image 1 of 3 Samsung ATIV Book 9 Plus Internal Fans Replacement, Internal Fans: step 3, image 2 of 3 Samsung ATIV Book 9 Plus Internal Fans Replacement, Internal Fans: step 3, image 3 of 3
    • The fans should be in the upper left corner of the laptop if the laptop is oriented with the battery in the bottom half.
    • Gently lift the fans' black connector strip out of the way.
  4. Samsung ATIV Book 9 Plus Internal Fans Replacement: step 4, image 1 of 2 Samsung ATIV Book 9 Plus Internal Fans Replacement: step 4, image 2 of 2
    • Using a Phillips head screwdriver, unscrew four 4.55 mm Phillips #000 screws that bind the fans.
  5. Samsung ATIV Book 9 Plus Internal Fans Replacement: step 5, image 1 of 1
    • Disconnect the white connectors by gently tugging on them.
    • Lift the fans from their positions.
2 other people completed this guide.
Rhannie Surel
137 Reputation
1 Guide authored
Baylor, Team 2-3, Grigsby Spring 2015 Member of Baylor, Team 2-3, Grigsby Spring 2015
BU-GRIGSBY-S15S2G3
4 Members
4 Guides authored
One Comment
I think that's to easy!
Ocean - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 14
All Time: 4,437
