Samsung ATIV Book 9 Plus Heatsink Assembly Replacement
  1. Samsung ATIV Book 9 Plus Heatsink Assembly Replacement, Back Cover: step 1, image 1 of 3 Samsung ATIV Book 9 Plus Heatsink Assembly Replacement, Back Cover: step 1, image 2 of 3 Samsung ATIV Book 9 Plus Heatsink Assembly Replacement, Back Cover: step 1, image 3 of 3
    • Turn the laptop upside down so that the underside of the laptop is facing you.
    • Use a Phillips #000 screwdriver to unscrew the 4.3 mm screws located on the edges and corners of the laptop.
  2. Samsung ATIV Book 9 Plus Heatsink Assembly Replacement: step 2, image 1 of 1
    • Lift the cover to reveal the interior of the laptop.
  3. Samsung ATIV Book 9 Plus Heatsink Assembly Replacement, Internal Fans: step 3, image 1 of 3 Samsung ATIV Book 9 Plus Heatsink Assembly Replacement, Internal Fans: step 3, image 2 of 3 Samsung ATIV Book 9 Plus Heatsink Assembly Replacement, Internal Fans: step 3, image 3 of 3
    • The fans should be in the upper left corner of the laptop if the laptop is oriented with the battery in the bottom half.
    • Gently lift the fans' black connector strip out of the way.
  4. Samsung ATIV Book 9 Plus Heatsink Assembly Replacement: step 4, image 1 of 2 Samsung ATIV Book 9 Plus Heatsink Assembly Replacement: step 4, image 2 of 2
    • Using a Phillips head screwdriver, unscrew four 4.55 mm Phillips #000 screws that bind the fans.
  5. Samsung ATIV Book 9 Plus Heatsink Assembly Replacement: step 5, image 1 of 1
    • Disconnect the white connectors by gently tugging on them.
    • Lift the fans from their positions.
  6. Samsung ATIV Book 9 Plus Heatsink Assembly Replacement, Heatsink Assembly: step 6, image 1 of 1
    • Using a Phillips head screwdriver #000 unscrew the motherboard from the rest of the components.
  7. Samsung ATIV Book 9 Plus Heatsink Assembly Replacement: step 7, image 1 of 1
    • Disconnect the two cables shown in the picture by gently pulling them off.
  8. Samsung ATIV Book 9 Plus Heatsink Assembly Replacement: step 8, image 1 of 1
    • Using a Phillips #000 screwdriver, unscrew the three labeled screws to detach the heatsink assembly.
Ryan Smith
193 Reputation
2 Guides authored
IUPUI, Team S7-G7, Wilson Spring 2019 Member of IUPUI, Team S7-G7, Wilson Spring 2019
IUPUI-WILSON-S19S7G7
3 Members
2 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 17
All Time: 638
