Samsung ATIV Book 9 Plus Charger Port Replacement
  1. Samsung ATIV Book 9 Plus Charger Port Replacement, Back Cover: step 1, image 1 of 3 Samsung ATIV Book 9 Plus Charger Port Replacement, Back Cover: step 1, image 2 of 3 Samsung ATIV Book 9 Plus Charger Port Replacement, Back Cover: step 1, image 3 of 3
    • Turn the laptop upside down so that the underside of the laptop is facing you.
    • Use a Phillips #000 screwdriver to unscrew the 4.3 mm screws located on the edges and corners of the laptop.
  2. Samsung ATIV Book 9 Plus Charger Port Replacement: step 2, image 1 of 1
    • Lift the cover to reveal the interior of the laptop.
  3. Samsung ATIV Book 9 Plus Charger Port Replacement, Charger Port: step 3, image 1 of 2 Samsung ATIV Book 9 Plus Charger Port Replacement, Charger Port: step 3, image 2 of 2
    • Unscrew the 4.3mm screws holding down the plastic cover using a #000 screwdriver. After the screws are out remove the cover.
    • Remove the 4.3 mm screw holding down the metal cover using a #000 screwdriver.
  4. Samsung ATIV Book 9 Plus Charger Port Replacement: step 4, image 1 of 1
    • Disconnect the charging port from the motherboard by gently tugging on the plastic part of the connection.
  5. Samsung ATIV Book 9 Plus Charger Port Replacement: step 5, image 1 of 1
    • Wedge a plastic opening tool or spudger in between the laptop casing and the port. Pry until you feel it release.
    • This will take some force because the port is glued to the casing.
  6. Samsung ATIV Book 9 Plus Charger Port Replacement: step 6, image 1 of 1
    • Remove the disconnected charger port.
3 other people completed this guide.
Casey Kauffman
329 Reputation
2 Guides authored
IUPUI, Team S6-G6, Baechle Fall 2017 Member of IUPUI, Team S6-G6, Baechle Fall 2017
IUPUI-BAECHLE-F17S6G6
3 Members
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 15
All Time: 1,927
