Samsung ATIV Book 9 Lite Hard Drive Replacement
  1. Samsung ATIV Book 9 Lite Hard Drive Replacement, Hard Drive: step 1, image 1 of 2 Samsung ATIV Book 9 Lite Hard Drive Replacement, Hard Drive: step 1, image 2 of 2
    • Put a protective lining such as a piece of cloth in between the screen and the keyboard when closed to protect your screen when performing this replacement.
    • Turn the laptop upside down to show the screws holding the back cover on.
    • Using a Phillips #0, remove the ten 4mm screws located around the edges and one central.
  2. Samsung ATIV Book 9 Lite Hard Drive Replacement: step 2, image 1 of 3 Samsung ATIV Book 9 Lite Hard Drive Replacement: step 2, image 2 of 3 Samsung ATIV Book 9 Lite Hard Drive Replacement: step 2, image 3 of 3
    • Use two plastic opening tools to separate the back cover from the laptop.
    • This may take some force because the back cover is snapped into place before the screws are used to keep it in place.
  3. Samsung ATIV Book 9 Lite Hard Drive Replacement: step 3, image 1 of 3 Samsung ATIV Book 9 Lite Hard Drive Replacement: step 3, image 2 of 3 Samsung ATIV Book 9 Lite Hard Drive Replacement: step 3, image 3 of 3
    • Using your hands or a plastic opening tool, release the yellow motherboard connection strip on both ends by lifting the clamps.
    • Remove the strip to reveal the hard drive.
  4. Samsung ATIV Book 9 Lite Hard Drive Replacement: step 4, image 1 of 2 Samsung ATIV Book 9 Lite Hard Drive Replacement: step 4, image 2 of 2
    • Using a Phillips #0, remove the two 3mm screws holding the hard drive in place.
    • Remove the hard drive by pulling it out with your hands.
2 other people completed this guide.
Phat Tran
786 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 54
All Time: 4,586
