Samsung ATIV Book 9 Lite Battery Replacement
  1. Samsung ATIV Book 9 Lite Battery Replacement, Battery: step 1, image 1 of 2 Samsung ATIV Book 9 Lite Battery Replacement, Battery: step 1, image 2 of 2
    • Put a protective lining such as a piece of cloth in between the screen and the keyboard when closed to protect your screen when performing this replacement.
    • Turn the laptop upside down to show the screws holding the back cover on.
    • Using a Phillips #0, remove the ten 4mm screws located around the edges and one central.
  2. Samsung ATIV Book 9 Lite Battery Replacement: step 2, image 1 of 3 Samsung ATIV Book 9 Lite Battery Replacement: step 2, image 2 of 3 Samsung ATIV Book 9 Lite Battery Replacement: step 2, image 3 of 3
    • Use two plastic opening tools to separate the back cover from the laptop.
    • This may take some force because the back cover is snapped into place before the screws are used to keep it in place.
  3. Samsung ATIV Book 9 Lite Battery Replacement: step 3, image 1 of 3 Samsung ATIV Book 9 Lite Battery Replacement: step 3, image 2 of 3 Samsung ATIV Book 9 Lite Battery Replacement: step 3, image 3 of 3
    • Using a Phillips #0, remove the seven 5mm screws highlighted in the image.
    • Using your hands, disconnect the battery's main cord from the main motherboard.
  4. Samsung ATIV Book 9 Lite Battery Replacement: step 4, image 1 of 2 Samsung ATIV Book 9 Lite Battery Replacement: step 4, image 2 of 2
    • Using your hands remove the battery from the computer.
3 other people completed this guide.
Phat Tran
786 Reputation
5 Guides authored
2 Comments
please where can i get the battery 🔋
Bethel Ugwudike - Reply
Please where can i get the battery for Samsung 930x5j910s5j940x5j
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 19
All Time: 1,687
