Samsung 351U Battery Replacement
  1. Samsung 351U Battery  Replacement, Battery: step 1, image 1 of 1
    • First, use a #0 Phillips screwdriver to remove the ten 4mm screws on the back of the laptop.
    • Remove the back cover using a spudger.
  2. Samsung 351U Battery  Replacement: step 2, image 1 of 1
    • Now, locate the (4 mm) screws on the battery and remove them.
  3. Samsung 351U Battery  Replacement: step 3, image 1 of 1
    • Now, detach the wire that is connected to the battery, which should now be removable.
Joseph Ortiz
119 Reputation
1 Guide authored
USF Tampa, Team 12-4, Eyestone Spring 2017 Member of USF Tampa, Team 12-4, Eyestone Spring 2017
USFT-EYESTONE-S17S12G4
4 Members
4 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 25
All Time: 867
