SONY Alpha NEX-3N Keypad Replacement
  1. SONY Alpha NEX-3N Keypad Replacement, Getting Started: step 1, image 1 of 2 SONY Alpha NEX-3N Keypad Replacement, Getting Started: step 1, image 2 of 2
    • Remove battery and card
  2. SONY Alpha NEX-3N Keypad Replacement, Back Case 1: step 2, image 1 of 3 SONY Alpha NEX-3N Keypad Replacement, Back Case 1: step 2, image 2 of 3 SONY Alpha NEX-3N Keypad Replacement, Back Case 1: step 2, image 3 of 3
    • Right side, remove 1 M1.4x3.7 screw
    • Left side, remove 3 M1.4x3.7 screws
    • Bottom side, remove 5 M1.4x3.7 screws, including 2 in battery bay. 2 of them out of this photo, you can find them.
    • Do NOT touch screws on the bottom of LCD assembly.
  3. SONY Alpha NEX-3N Keypad Replacement, Back Case 2: step 3, image 1 of 1
    • Pop the flash.
    • In flash room, remove 1 (one) M1.4x3.8 black screw.
  4. SONY Alpha NEX-3N Keypad Replacement, Back Case 3: step 4, image 1 of 3 SONY Alpha NEX-3N Keypad Replacement, Back Case 3: step 4, image 2 of 3 SONY Alpha NEX-3N Keypad Replacement, Back Case 3: step 4, image 3 of 3
    • Remove LCD hinge cover, by sliding to the left.
    • Remove back cover, actually just a plastic frame.
  5. SONY Alpha NEX-3N Keypad Replacement, LCD assembly: step 5, image 1 of 2 SONY Alpha NEX-3N Keypad Replacement, LCD assembly: step 5, image 2 of 2
    • Remove 1 M1.4x2 screw
    • Remove another M1.4x2 screw, sorry for the angle.
  6. SONY Alpha NEX-3N Keypad Replacement, LCD Assembly: step 6, image 1 of 3 SONY Alpha NEX-3N Keypad Replacement, LCD Assembly: step 6, image 2 of 3 SONY Alpha NEX-3N Keypad Replacement, LCD Assembly: step 6, image 3 of 3
    • CAUTION. Sony makes world's MOST BRITTLE FPC!
    • Loosen LCD assemble with caution!
    • Release FPC cable, the connector is flip type.
  7. SONY Alpha NEX-3N Keypad Replacement, The LCD assembly: step 7, image 1 of 1
    • The LCD assembly
  8. SONY Alpha NEX-3N Keypad Replacement, Keypad: step 8, image 1 of 3 SONY Alpha NEX-3N Keypad Replacement, Keypad: step 8, image 2 of 3 SONY Alpha NEX-3N Keypad Replacement, Keypad: step 8, image 3 of 3
    • Lift the keypad.
    • Detach FPC
Terrance
6,368 Reputation
17 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 6
All Time: 65
