SAMSUNG ATIV Book 9 Plus NP930X5J-S01US Screen Replacement
  1. SAMSUNG ATIV Book 9 Plus NP930X5J-S01US Screen Replacement, Battery: step 1, image 1 of 2 SAMSUNG ATIV Book 9 Plus NP930X5J-S01US Screen Replacement, Battery: step 1, image 2 of 2
    • Remove the ten 4.3mm Phillips #00 screws from the bottom cover of the laptop.
  2. SAMSUNG ATIV Book 9 Plus NP930X5J-S01US Screen Replacement: step 2, image 1 of 3 SAMSUNG ATIV Book 9 Plus NP930X5J-S01US Screen Replacement: step 2, image 2 of 3 SAMSUNG ATIV Book 9 Plus NP930X5J-S01US Screen Replacement: step 2, image 3 of 3
    • Press the button to release the bottom cover.
  3. SAMSUNG ATIV Book 9 Plus NP930X5J-S01US Screen Replacement: step 3, image 1 of 2 SAMSUNG ATIV Book 9 Plus NP930X5J-S01US Screen Replacement: step 3, image 2 of 2
    • Remove the five 4.3mm Phillips #00 screws from the battery.
  4. SAMSUNG ATIV Book 9 Plus NP930X5J-S01US Screen Replacement: step 4, image 1 of 2 SAMSUNG ATIV Book 9 Plus NP930X5J-S01US Screen Replacement: step 4, image 2 of 2
    • Lift the battery with both hands and remove.
  5. SAMSUNG ATIV Book 9 Plus NP930X5J-S01US Screen Replacement, Screen: step 5, image 1 of 3 SAMSUNG ATIV Book 9 Plus NP930X5J-S01US Screen Replacement, Screen: step 5, image 2 of 3 SAMSUNG ATIV Book 9 Plus NP930X5J-S01US Screen Replacement, Screen: step 5, image 3 of 3
    • Disconnect the display cable from the motherboard.
  6. SAMSUNG ATIV Book 9 Plus NP930X5J-S01US Screen Replacement: step 6, image 1 of 2 SAMSUNG ATIV Book 9 Plus NP930X5J-S01US Screen Replacement: step 6, image 2 of 2
    • Disconnect the black and white antenna cables from the Wi-Fi card.
  7. SAMSUNG ATIV Book 9 Plus NP930X5J-S01US Screen Replacement: step 7, image 1 of 2 SAMSUNG ATIV Book 9 Plus NP930X5J-S01US Screen Replacement: step 7, image 2 of 2
    • Remove the five 4mm Phillips #00 screws from the motherboard retaining brackets.
  8. SAMSUNG ATIV Book 9 Plus NP930X5J-S01US Screen Replacement: step 8, image 1 of 2 SAMSUNG ATIV Book 9 Plus NP930X5J-S01US Screen Replacement: step 8, image 2 of 2
    • Remove the eight silver 4.2mm Phillips #00 screws from the corner.
  9. SAMSUNG ATIV Book 9 Plus NP930X5J-S01US Screen Replacement: step 9, image 1 of 3 SAMSUNG ATIV Book 9 Plus NP930X5J-S01US Screen Replacement: step 9, image 2 of 3 SAMSUNG ATIV Book 9 Plus NP930X5J-S01US Screen Replacement: step 9, image 3 of 3
    • Pry up the metal hinges from the laptop.
  10. SAMSUNG ATIV Book 9 Plus NP930X5J-S01US Screen Replacement: step 10, image 1 of 3 SAMSUNG ATIV Book 9 Plus NP930X5J-S01US Screen Replacement: step 10, image 2 of 3 SAMSUNG ATIV Book 9 Plus NP930X5J-S01US Screen Replacement: step 10, image 3 of 3
    • Place the screen on its back side and hold the battery-side of the laptop. In an upward motion, remove the back set off and set it aside.
Sean Kim
640 Reputation
4 Guides authored
UW Tacoma, Team S1-G2, Liner Spring 2018 Member of UW Tacoma, Team S1-G2, Liner Spring 2018
UWT-LINER-S18S1G2
5 Members
4 Guides authored
One Comment
There’s no need to remove the battery. Just disconnect its power socket if you want to be ‘careful’.
Steerpike - Reply
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 12
All Time: 597
