Rotor Riot Thumbstick Replacement
  1. Rotor Riot Thumbstick Replacement, Remove the iPhone mount: step 1, image 1 of 3 Rotor Riot Thumbstick Replacement, Remove the iPhone mount: step 1, image 2 of 3 Rotor Riot Thumbstick Replacement, Remove the iPhone mount: step 1, image 3 of 3
    • Use your fingers to remove the screw on the back side of the controller securing the iPhone mount.
    • Remove the iPhone mount.
  2. Rotor Riot Thumbstick Replacement, Unscrew the back cover: step 2, image 1 of 1
    • Use a T6 Torx screwdriver to remove the eight 9.2 mm-long screws securing the back cover.
    • Don't try to remove the back cover all the way yet! It's still connected to the mainboard.
  3. Rotor Riot Thumbstick Replacement, Swing open the back cover: step 3, image 1 of 3 Rotor Riot Thumbstick Replacement, Swing open the back cover: step 3, image 2 of 3 Rotor Riot Thumbstick Replacement, Swing open the back cover: step 3, image 3 of 3
    • Lift up the back cover of the controller.
    • Lift the back cover to a 45 degree angle and place it next to the controller.
    • Don't strain the interconnect cable during this procedure.
  4. Rotor Riot Thumbstick Replacement, Disconnect the phone connector cable: step 4, image 1 of 3 Rotor Riot Thumbstick Replacement, Disconnect the phone connector cable: step 4, image 2 of 3 Rotor Riot Thumbstick Replacement, Disconnect the phone connector cable: step 4, image 3 of 3
    • Use a spudger to disconnect the phone connector cable from the mainboard.
  5. Rotor Riot Thumbstick Replacement, Remove the back cover: step 5, image 1 of 1
    • Remove the back cover.
  6. Rotor Riot Thumbstick Replacement, Remove the shoulder buttons: step 6, image 1 of 2 Rotor Riot Thumbstick Replacement, Remove the shoulder buttons: step 6, image 2 of 2
    • Remove the shoulder buttons by lifting them out of the case.
  7. Rotor Riot Thumbstick Replacement, Unscrew the mainboard: step 7, image 1 of 1
    • Use a Phillips screwdriver to remove the four 7.0 mm-long screws securing the mainboard.
  8. Rotor Riot Thumbstick Replacement, Flip over the mainboard: step 8, image 1 of 3 Rotor Riot Thumbstick Replacement, Flip over the mainboard: step 8, image 2 of 3 Rotor Riot Thumbstick Replacement, Flip over the mainboard: step 8, image 3 of 3
    • Flip over the mainboard and place it above the controller housing.
    • Avoid tensioning the trigger button cables during this procedure and don't try to remove the mainboard all the way yet! It is still connected to the controller housing.
  9. Rotor Riot Thumbstick Replacement, Remove the thumbsticks: step 9, image 1 of 3 Rotor Riot Thumbstick Replacement, Remove the thumbsticks: step 9, image 2 of 3 Rotor Riot Thumbstick Replacement, Remove the thumbsticks: step 9, image 3 of 3
    • Use your fingers to remove the left thumbstick by pulling it upwards and off the left joystick.
    • Repeat this procedure for the right tumbstick.
Repair didn’t go as planned? Check our Answers community for help.
Adriana Zwink
49,581 Reputation
167 Guides authored
iFixit Member of iFixit
Staff
137 Members
17,643 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 15
All Time: 309
