Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement
  1. Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement, How to Open the Rocketfish RF-WHTIB-A Receiver: step 1, image 1 of 1
    • Remove the 4 rubber tabs on the bottom side of the receiver.
  2. Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement: step 2, image 1 of 1
    • Unscrew the four 12 mm screws on the bottom side of the receiver.
    • Use a Phillips #1 screwdriver for this step.
  3. Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement: step 3, image 1 of 2 Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement: step 3, image 2 of 2
    • Remove top casing from the receiver.
    • The receiver top casing is difficult to remove. Internal clasps may have to be broken in order to remove the top casing (this will not effect the device's function)
  4. Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement, Receiver Wireless Audio Module Chip: step 4, image 1 of 1
    • Unscrew the 10 mm screw holding the wireless audio module.
  5. Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement: step 5, image 1 of 2 Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement: step 5, image 2 of 2
    Tool used on this step:
    Buy
    • Slide the black retaining flap securing the ribbon cable away from the white bar.
    • There should be only a small space between the white bar and black retaining flap.
    • You may want to use tweezers for this step.
  6. Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement: step 6, image 1 of 1
    • Using your fingers, slide the ribbon cable out from the under the black retaining flap to completely disconnect it from the device.
To install the new wireless audio module chip, follow these instructions in reverse order.
Caitlin Charlton
756 Reputation
6 Guides authored
Baylor, Team 4-2, Williams Spring 2015 Member of Baylor, Team 4-2, Williams Spring 2015
BU-WILLIAMS-S15S4G2
3 Members
6 Guides authored
One Comment
This is a very long time later, but where do you get the receiver chip??? Rocket fish doesn't support the product anymore
Michael Jay - Reply
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 25
All Time: 1,983
