Revlon RVDR5061 Fan/Motor Assembly Replacement
  1. Revlon RVDR5061 Fan/Motor Assembly Replacement, Fan/Motor Assembly: step 1, image 1 of 1
    • Using a Phillips #3 screwdriver, remove the single 25 mm Phillips head screw in the handle by turning it counterclockwise.
  2. Revlon RVDR5061 Fan/Motor Assembly Replacement: step 2, image 1 of 1
    • Using a medium flathead screwdriver or better yet iFixit plastic opening tools, gently pry apart the handle from the power cord.
  3. Revlon RVDR5061 Fan/Motor Assembly Replacement: step 3, image 1 of 1
    • After pulling apart the housing, all internals will be free to remove.
  4. Revlon RVDR5061 Fan/Motor Assembly Replacement: step 4, image 1 of 3 Revlon RVDR5061 Fan/Motor Assembly Replacement: step 4, image 2 of 3 Revlon RVDR5061 Fan/Motor Assembly Replacement: step 4, image 3 of 3
    • The fan/motor assembly is connected to the heating element assembly at two points need to be desoldered. After pulling the attached wires through the holes the fan/motor assembly will be free from the heating element assembly. Congratulations you have now completely removed the fan/motor assembly from this hair dryer!
Curtis
159 Reputation
1 Guide authored
IUPUI, Team S2-G2, Wilson Summer 2018 Member of IUPUI, Team S2-G2, Wilson Summer 2018
IUPUI-WILSON-SU18S2G2
4 Members
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 14
All Time: 1,085
