Revising the brewing unit of Nivona Caferomatica
  1. Revising the brewing unit of Nivona Caferomatica, Brewing Unit maintenance: step 1, image 1 of 1
    • Remove the brewing unit from the device.
  2. Revising the brewing unit of Nivona Caferomatica: step 2, image 1 of 1
    • Take off the cap covering the screwhole in one corner. The cap ensures a better fit of the brewing unit.
    • Note: some versions of the brewing unit do not have this cap.
  3. Revising the brewing unit of Nivona Caferomatica: step 3, image 1 of 1
    • Remove the single black Torx T10 screw fixing the opening handle.
    • Using a certain amount of force pull the opening handle out of the guidance near the red button.
    • Rotate the handle 90 degrees counterclockwise, then lift it off.
  4. Revising the brewing unit of Nivona Caferomatica: step 4, image 1 of 2 Revising the brewing unit of Nivona Caferomatica: step 4, image 2 of 2
    • Unclip the upper protection panel, then remove it by lifting it up.
  5. Revising the brewing unit of Nivona Caferomatica: step 5, image 1 of 1
    • Remove six Torx T15 screws holding together the brewing unit. The screwholes are rather deep.
    • Lift the upper half of the brewing unit up.
  6. Revising the brewing unit of Nivona Caferomatica: step 6, image 1 of 2 Revising the brewing unit of Nivona Caferomatica: step 6, image 2 of 2
    • The inside of the brewing unit ist exposed. You can see:
    • The upper piston and its gasket.
    • The funnel for the coffee grounds
    • The lower piston.
    • The hold-down clamp
  7. Revising the brewing unit of Nivona Caferomatica: step 7, image 1 of 3 Revising the brewing unit of Nivona Caferomatica: step 7, image 2 of 3 Revising the brewing unit of Nivona Caferomatica: step 7, image 3 of 3
    • Remove the funnel.
    • Rotate the lower piston counterclockwise and lift it off.
    • Lift off the upper piston. There ist still a hose connecting the piston to the coffee outlet. In top there ist also the downholder of the brewing unit.
    • Sometimes this downholder ist torn and the coffee leaks out of the brewing unit and does not fill your cup. Inspect the downholder for cracks. You can fix this using a special repair kit.
  8. Revising the brewing unit of Nivona Caferomatica: step 8, image 1 of 3 Revising the brewing unit of Nivona Caferomatica: step 8, image 2 of 3 Revising the brewing unit of Nivona Caferomatica: step 8, image 3 of 3
    • Remove the hose connecting the upper piston and the coffee outlet.
    • Remove the upper piston.
    • Remove the Torx T20 screw from the screen of the upper piston.
    • Take off the cover of the gasket and the gasket.
    • Replace the gaskets of the upper piston, the coffee outlet and water connector.
    • The lip of the piston gasket must point towards the pressure, i.e. downwards.
    • Clean thoroughly all parts. Use food-proof silicone grease to lubricate the gaskets.
  9. Revising the brewing unit of Nivona Caferomatica: step 9, image 1 of 1
    • The crema-valve is located in the interior of the upper piston. It is fixed by two Torx T10 screws.
    • Remove both screws. Lift off the valve. Inspect it and clean it.
    • Note: there is another gasket on the shaft of the lower piston. Replacing it is difficult.
    • Lubricate all sliding parts with food-proof silicone grease. Verify the smooth operating of the brewing unit.
Apply all steps in reverse order to re-assemble the device.
3 other people completed this guide.
Special thanks to these translators:
de en
100%
jana° is helping us fix the world! Want to contribute?
Start translating ›
VauWeh
207,338 Reputation
255 Guides authored
Repair is War on Entropy Member of Repair is War on Entropy
Community
26 Members
1,173 Guides authored
0 Comments
Past 24 Hours: 9
Past 7 Days: 36
Past 30 Days: 147
All Time: 9,516
