Replacing iPhone 5 Battery
Archived Guide
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
Request Guide Deletion
This guide will be reviewed by admins for deletion.
User-Contributed Guide
This guide will show you how to replace the battery on your iPhone 5
  • Author: jimenezser
  • Time required: 10 Minutes
  • Difficulty: Easy
  • Add Note x
  • x 8
This guide has been updated by iFixit staff! Read the new, official guide here.
iPhone 4 and iPhone 4S batteries aren't compatible with iPhone 5 due its size, capacity and voltage
All photos are property of iFixit staff
Image #1
  • This guide will teach you how to replace your battery on your iPhone 5.
Image #1 Image #2 Image #3
Add Note Edit Step 2 — Open the iPhone  ¶
Add Note Edit Step 3 — Unplug screen cable  ¶
  • Remove this 3 #00 Philips screws (The screwdriver is included in 26 bit driver set)
  • Then, lift the aluminium cover and with the spudger, unplug the screen cable from its socket
Add Note Edit Step 4 — Battery  ¶
  • Remove this (another) 3 #00 Philips screws securing the battery connector
  • With the spudger, lift the battery conector from its socket
  • With the help of the tab "Authorized service provider only" and a spudger, lift the battery
  • The battery has mild adhesive, so don't pull it with excessive force, remove it slowly.
  • When reassembling, it isn't necessary to reapply new glue
Required Tools
Spudger
$2.95 · 50+ In stock
Small Suction Cup
26 Bit Driver Kit
$19.95 · 43 In stock
iPhone 5-Point Pentalobe Screwdriver
$12.95 · 50+ In stock
Related Products
