Replacing the hard drive of the HP 15-bs015dx laptop
  1. Replacing the hard drive of the HP 15-bs015dx laptop, Remove the Battery - Part 1: step 1, image 1 of 3 Replacing the hard drive of the HP 15-bs015dx laptop, Remove the Battery - Part 1: step 1, image 2 of 3 Replacing the hard drive of the HP 15-bs015dx laptop, Remove the Battery - Part 1: step 1, image 3 of 3
    • Put the laptop facing down
    • Move the left battery safe lock to the right
  2. Replacing the hard drive of the HP 15-bs015dx laptop, Remove the Battery - Part 2: step 2, image 1 of 3 Replacing the hard drive of the HP 15-bs015dx laptop, Remove the Battery - Part 2: step 2, image 2 of 3 Replacing the hard drive of the HP 15-bs015dx laptop, Remove the Battery - Part 2: step 2, image 3 of 3
    • Slide the right battery safe lock to the left
    • This lock is harder than the previous, with this the battery should pop-up.
  3. Replacing the hard drive of the HP 15-bs015dx laptop, Remove the 6 visibles screws: step 3, image 1 of 3 Replacing the hard drive of the HP 15-bs015dx laptop, Remove the 6 visibles screws: step 3, image 2 of 3 Replacing the hard drive of the HP 15-bs015dx laptop, Remove the 6 visibles screws: step 3, image 3 of 3
    • Use a Philips 0 screwdriver
  4. Replacing the hard drive of the HP 15-bs015dx laptop, Remove the 4 hidden screws: step 4, image 1 of 3 Replacing the hard drive of the HP 15-bs015dx laptop, Remove the 4 hidden screws: step 4, image 2 of 3 Replacing the hard drive of the HP 15-bs015dx laptop, Remove the 4 hidden screws: step 4, image 3 of 3
    • Use a straw to take off just enough of the rubber feet of the 4 corners
    • Use a Phillips screwdriver 0
    • Replace each rubber foot in place after removing the screws
    • You will have a total of 10 screws
  5. Replacing the hard drive of the HP 15-bs015dx laptop, Remove the DVD unit: step 5, image 1 of 2 Replacing the hard drive of the HP 15-bs015dx laptop, Remove the DVD unit: step 5, image 2 of 2
    • It will go out easily with or without a straw
    • You can check the model number
  6. Replacing the hard drive of the HP 15-bs015dx laptop, Separate the pieces of the chassis part 1: step 6, image 1 of 3 Replacing the hard drive of the HP 15-bs015dx laptop, Separate the pieces of the chassis part 1: step 6, image 2 of 3 Replacing the hard drive of the HP 15-bs015dx laptop, Separate the pieces of the chassis part 1: step 6, image 3 of 3
    • Flip the laptop and open it
    • Use a plastic tool or a straw to separate the pieces of the chassis
  7. Replacing the hard drive of the HP 15-bs015dx laptop, Separate the pieces of the chassis part 2: step 7, image 1 of 3 Replacing the hard drive of the HP 15-bs015dx laptop, Separate the pieces of the chassis part 2: step 7, image 2 of 3 Replacing the hard drive of the HP 15-bs015dx laptop, Separate the pieces of the chassis part 2: step 7, image 3 of 3
    • Flip the laptop and separate the inferior cover of the chassis
    • Hard Drive 2.5" SATA
    • 2 RAM memory slots type DDR4 SO-DIMM
    • CPU Intel 7th generation
    • Active heat sink (fan)
    • Wireless card
    • Watch battery, 3V. CR2030
  8. Replacing the hard drive of the HP 15-bs015dx laptop, Remove the three screws from the frame: step 8, image 1 of 3 Replacing the hard drive of the HP 15-bs015dx laptop, Remove the three screws from the frame: step 8, image 2 of 3 Replacing the hard drive of the HP 15-bs015dx laptop, Remove the three screws from the frame: step 8, image 3 of 3
    • 3 screws
    • Use a Phillips 0 screwdriver
    • Remove the frame
  9. Replacing the hard drive of the HP 15-bs015dx laptop, Remove the hard drive: step 9, image 1 of 3 Replacing the hard drive of the HP 15-bs015dx laptop, Remove the hard drive: step 9, image 2 of 3 Replacing the hard drive of the HP 15-bs015dx laptop, Remove the hard drive: step 9, image 3 of 3
    • Tilt the hard drive up
    • Disconnect the hard drive from its SATA port
    • The hard drive is 7mm high. 1TB capacity.
For re-assembly of your device, follow these instructions in reverse.
9 other people completed this guide.
Special thanks to these translators:
es en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Marcos Mora
3,672 Reputation
11 Guides authored
6 Comments
Disculpa, yo tengo esta laptop, mi hard drive hdd se estropeó y quisiera cambiarlo por un ssd, sin embargo no se que tipo de ssd necesito, si eres tan amable de aclararme mi duda, se agradecería.
el_kevinsillo.777 - Reply
Saludos. Te toca comprar un SSD tipo SATA. Puedes revisar mi perfil, ahí tengo mis RRSS y me puede contactar.
Marcos Mora -
Great but how do you get the software to reinstall on the new hard drive?
Jared Brice - Reply
That would require a whole new guide. I have some of those on my YouTube channel, link in my ifixit profile.
Bottom line: A flash drive with a Windows installer on it.
Marcos Mora -
Follow this POS guide and you WILL break the 4 mounting tabs for the hinges as NOTHING was mentioned about the 4 screws holding them down!
Mochanic - Reply
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 103
All Time: 6,902
