Replacing iPhone 4 5-Point Pentalobe Screws
Featured Guide
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
5-point Pentalobe screws replacement.
  • Add Note x
  • x 260
Apple has substituted the two bottom Phillips screws near the dock connector with 5-point "Pentalobular" screws.
This guide will illustrate how to replace the Pentalobe screws with good ol' regular Phillips screws.
Relevant Parts
Image #1
Add Note Edit Step 1 — 5-Point Pentalobe Screws  ¶
  • Before we proceed, let's make sure you have the correct tools for the job.
  • iFixit's iPhone 4/4S Liberation Kit includes:
    • One 5-Point "Pentalobe" screwdriver
    • One #00 Phillips screwdriver
    • Two 3.6 mm "Liberation" Phillips screws
  • Are you ready to break the shackles of hardware oppression and liberate your iPhone? Let's rock!
Image #1 Image #2
Add Note Edit Step 2  ¶
  • Use the Pentalobe screwdriver to remove the two 3.6 mm Pentalobe screws near the dock connector.
  • The 5-Point Pentalobe screwdriver should only be used a limited number of times because it has the potential to strip the screws.
Image #1 Image #2
Add Note Edit Step 3  ¶
  • Peel and remove the two 3.6 mm Phillips screws from the iPhone Liberation Card.
  • Both the Phillips and Pentalobe screws are really small. How small? See for yourself (highlighted in the second picture).
Image #1
Add Note Edit Step 4  ¶
  • Insert the two 3.6 mm Phillips screws into the screw holes using the provided #00 Phillips screwdriver.
  • Huzzah! Your iPhone should now be liberated from those pesky "Pentalobular" screws.
Related Products
$9.95 · 50+ In stock
