Replacing The PODZ Port
  1. Replacing The PODZ Port, Rear Cover PODZ Port: step 1, image 1 of 3 Replacing The PODZ Port, Rear Cover PODZ Port: step 1, image 2 of 3 Replacing The PODZ Port, Rear Cover PODZ Port: step 1, image 3 of 3
    • Remove the 6 screws securing the lens cover bezel using a #00 Phillips screwdriver. This will allow you to remove the bezel and lens cover.
  2. Replacing The PODZ Port: step 2, image 1 of 1
    • Remove the metal camera body cover by sliding it toward the lens end of the camera.
  3. Replacing The PODZ Port: step 3, image 1 of 1
    • Remove 2 screws on the bottom of the camera body using a #00 Phillips screwdriver.
  4. Replacing The PODZ Port: step 4, image 1 of 1
    • Remove the 3 screws that secure the camera to the body using a #00 Phillips screwdriver.
  5. Replacing The PODZ Port: step 5, image 1 of 1
    • Use a plastic pry tool to remove the plastic ring covering the rear screws.
  6. Replacing The PODZ Port: step 6, image 1 of 2 Replacing The PODZ Port: step 6, image 2 of 2
    • Remove the 8 screws around the perimeter of the back cover.
    • Remove the 2 screws in the PODZ port.
  7. Replacing The PODZ Port: step 7, image 1 of 1
    • Slide PODZ port out of the camera body.
    • Disconnect ribbon cable from the back of the PODZ port.
Christopher Brandl
673 Reputation
5 Guides authored
UW Stout, Team S6-G2, Ogden Fall 2018 Member of UW Stout, Team S6-G2, Ogden Fall 2018
UWSTOUT-OGDEN-F18S6G2
4 Members
5 Guides authored
One Comment
How do you reconnect the ribbon cable to the back of the PODZ port when you reassemble?
Peter Niepel - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 15
All Time: 601
