Introduction
Use this guide to replace your mini's IR sensor/sleep LED assembly. Replacing this component requires removal of the logic board and most other components in your mini.
Place your thumbs in the depressions cut into the bottom cover.
Rotate the bottom cover counter-clockwise until the white dot painted on the bottom cover is aligned with the ring inscribed on the outer case.
Remove the two 11.3 mm T6 Torx screws securing the fan to the logic board near the antenna plate.
Remove the following screws securing the antenna plate to the mini:
Two 6.6 mm T8 Torx screws
Two 5.0 mm T8 Torx or 2.0 mm Hex screws (either screwdriver will work)
When putting back together:
Use the flat end of a spudger to pry the hard drive connector up from its socket on the logic board.
Tool used on this step:Mac mini Logic Board Removal Tool$4.99
Insert the Mac mini Logic Board Removal Tool into the two holes highlighted in red. Be sure it makes contact with the top side of outer case below the logic board before proceeding.
Carefully pull the tool toward the I/O board. The logic board and I/O board assembly should slightly slide out of the outer case.
Remove the Mac mini Logic Board Removal tool.
Pull the hard drive away from the front edge of the mini and remove it from the outer case.
Remove the 7.9 mm T6 Torx screw securing the power supply and hard drive tray to the outer case.
Remove the 7.9 mm T6 Torx screw securing the hard drive tray to the outer case.
Carefully de-route the IR sensor cables from the channel in the hard drive tray.
14 other people completed this guide.
4 Comments
I'm about to embark on this journey. lol
Messed up the pins that go onto the board because I forgot to unpin it when upgrading the HD to an SSD.
Computer works fine, but no infrared, which I never use anyway, and no indicator light.
COMPUTER MUST BE PERFECT so I ordered the part from powerbookmedic.
where can i buy IR sensor?
