Replace RAM memory from why! WDi7SSD
  1. Replace RAM memory from why! WDi7SSD, why! WDi7SSD Opening procedure: step 1, image 1 of 3 Replace RAM memory from why! WDi7SSD, why! WDi7SSD Opening procedure: step 1, image 2 of 3 Replace RAM memory from why! WDi7SSD, why! WDi7SSD Opening procedure: step 1, image 3 of 3
    • Make sure the computer is disconnected from the power source.
    • Flip the computer over.
    • Remove the six screws with a 2 mm Allen key.
    • Carefully remove the back panel, as well the left and right panel.
  2. Replace RAM memory from why! WDi7SSD: step 2, image 1 of 1
    • Now flip up the base panel to which all components are attached.
  3. Replace RAM memory from why! WDi7SSD, RAM memory: step 3, image 1 of 2 Replace RAM memory from why! WDi7SSD, RAM memory: step 3, image 2 of 2
    • Disconnect the cable that goes over the RAM bars.
  4. Replace RAM memory from why! WDi7SSD: step 4, image 1 of 2 Replace RAM memory from why! WDi7SSD: step 4, image 2 of 2
    • Press down the small metal springs on both sides and push them to the side.
    • The latch loosens and can be removed.
    • Perform both steps again to remove the second latch.
To reassemble the unit, follow the instructions in reverse order.
Special thanks to these translators:
de en
100%
oldturkey03 is helping us fix the world! Want to contribute?
Start translating ›
Felice Suglia
30,908 Reputation
264 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 5
All Time: 114
