Repairing Tungsten T3 Screen
Bullets!
Bullets!
Better coordination with markups and the color/type of bullets will help make this guide more clear!
Needs Better Images
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Markup Mishap
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Step Trimmer
Step Trimmer
This guide has unnecessary steps. Trim them to be more concise!
User-Contributed Guide
This manual will successfully take you step by step through the process of replacing the screen in the Tungsten T3 Palm Pilot.
When beginning the process of replacing your Motherboard control panel have all of your tools readily at hand. These can be purchased through IFixit.com
Image #1
Add Note Edit Step 1 — Screen  ¶
  • To remove the cover press down on the center indentation and remove from device.
  • Reminder: If you have a memory card inserted into your device make sure to remove it.
Image #1
Add Note Edit Step 2  ¶
  • There will be a set of screws located on each side of your device. Remove these by using a Phillips head screwdriver.
Image #1
Add Note Edit Step 3  ¶
  • The back panel must be removed in order to proceed. Slide the cover so that it is fully extended.
  • The arrows in the picture indicate two small holes located at the top of the device. Insert a paper clip or a tack simultaneously into each of these holes and moderately push downward.
  • The springs will give as pressure is exerted. Once you feel this take place, pull down the cover with the paper clip/tack while continuing to push downward. This will release the back cover.
Image #1
Add Note Edit Step 4  ¶
  • Now the buttons and sliding tray will be connected to the main body only by an orange cable.
  • Gently peel this cable from the device.
Image #1
Add Note Edit Step 5  ¶
  • Make sure that the cable remains connected to the buttons. Do not sever its connection to the sliding tray.
  • Disconnect the cable from the main body of the device by pulling upward.
  • Set aside the buttons and slide tray, making sure the orange cable is with it.
Image #1
Add Note Edit Step 6  ¶
  • The arrows indicate two small screws. Using a Phillips head screwdriver, remove them.
Image #1
Add Note Edit Step 7  ¶
  • To open the device, the sides must be (with moderate force) pried apart using a prying tool as seen in the picture.
  • Both sides must be separated from one another.
  • Tip: The right side may be slightly more difficult. It will be easiest to begin on the left.
  • Beginning with the left side, gently pry at the division of the face plates until they separate from one another.
  • Repeat this process on the other side of the device.
Image #1
Add Note Edit Step 8  ¶
  • Hint: There will be pressure points along the side (as seen in the picture). Exerting pressure in these points will allow the sides to separate more easily.
Next » « Previous
Popular Products
iPad 2 Front Panel Assembly
$134.95 · 50+ In stock
Detailing Brush
$2.95 · 22 In stock
Pro Tech Toolkit Expansion 1
$79.95 · 10 In stock
T10 Torx Security Bit Screwdriver
$6.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 19 In stock
