Page 1 of 1
Repairing Texas Instruments TI-92 Screen Cover
User-Contributed Guide
This guide is not managed by iFixit staff.
Inconsistent Images
This guide contains images that are inconsistent with prerequisites.
- Author: Daniel Maldonado
- Time required: 10 minutes
- Difficulty: Moderate
In this guide we will show how to access and remove the plastic covering and protecting the LCD display.
Sections
- Back Cover 3 steps
- Batteries 1 step
- Back Case 6 steps
- Screen Cover 4 steps
- View:
- Paginated
- Full width
Edit Step 3 ¶
"Locking Tab"
To remove the back cover, slide the cover away from the locking tab towards the bottom of the calculator until the cover no longer slides.
Then with the front of the calculator facing down, pull up on the back cover.
The calculator should now be orientated with the front facing down, as shown in picture 2.
Edit Step 4
Batteries
The Batteries are now exposed and the calculator is face down with the back towards you.
Remove the bottom batteries by pressing the battery towards you while pulling it out from the far end.
If you can not do the previous step with your finger try using a flat ended tool such as an Ipod opening tool.
After the bottom battery has been removed push or slide the other(top) battery towards you until it is fully exposed in the battery slot.
Now simply remove the battery.
Edit Step 8 ¶
Using the Ipod Opening Tool pull up on both sides of the rectangular module while keeping the rest of the calculator flat on a surface face down
You may get a lot of resistance from the module. Do not use too much force as you risk damage. Use small amounts of force to work the module out.
Edit Step 14 ¶
The yellow circles and the spots on the other side of the screen from the circles represent circular tabs holding the plastic screen cover in.
Use a flat tool such as the Ipod Opening tool to separate the screen from the tabs.
When removing the screen, the top part of the tabs holding the screen will break in order to allow for movement.
If tilting the panel to remove screen, be careful as the buttons may fall out. To avoid this, keep rubber cover over buttons during operations and keep angle of tilt at a minimum.
This guide has been completed 0 times.
Page 1 of 1
