Repairing Sony Ericsson W200i Keypad
User-Contributed Guide
This guide will be helpful for replacing the keypad that is located beneath front case. This guide will provide step by step instructions on how to carefully and properly replace the keypad.
Replacing the keypad requires that the front case be removed.
Relevant Parts
  • Keypad , Sony Ericsson W200i keypad http://www.dinodirect.com/Sony-Ericsson-W200-Keypad-Black.html
Image #1 Image #2
  • Slide the battery cover up and off the phone.
Image #1 Image #2
Add Note Edit Step 2  ¶
  • Pop the battery out of its slot by lifting it up.
Image #1 Image #2 Image #3
Add Note Edit Step 3 — Front Case  ¶
  • Insert the plastic opening tool in between the front case and the back case.
  • Apply downward pressure to make the case lift upwards, thus popping the front case off.
    • Use caution when removing the front case. It may seem stuck but just ease it out.
Image #1 Image #2
Add Note Edit Step 4 — Keypad  ¶
  • Using the plastic opening tool, press down anywhere on the keypad to separate it from the front case.
Required Tools
T6 Torx Screwdriver
$4.95 · 20 In stock
Plastic Opening Tools
$2.95 · 50+ In stock
Recommended Tools
Universal Drive Adapter
$29.95 · 50+ In stock
Inspection Scope
$39.95 · 18 In stock
Frictionless Ratchet
$24.95 · 2 In stock
Portable Anti-Static Mat
$24.95 · 17 In stock
Popular Products
