Sony Cyber-shot DSC-S2100 LCD Replacement
  1. Sony Cyber-shot DSC-S2100 LCD Replacement, LCD: step 1, image 1 of 3 Sony Cyber-shot DSC-S2100 LCD Replacement, LCD: step 1, image 2 of 3 Sony Cyber-shot DSC-S2100 LCD Replacement, LCD: step 1, image 3 of 3
    • The broken LCD is immediately visible when the camera is turned on.
    • Remove the batteries and, if so equipped, the memory card.
    • Remove the three Philips screws from the bottom of the camera with a Phillips #00 Screwdriver.
  2. Sony Cyber-shot DSC-S2100 LCD Replacement: step 2, image 1 of 3 Sony Cyber-shot DSC-S2100 LCD Replacement: step 2, image 2 of 3 Sony Cyber-shot DSC-S2100 LCD Replacement: step 2, image 3 of 3
    • Remove the two Philips screws from the right side of the camera.
    • Remove the two Philips screws from the left side of the camera.
    • Split the housing by either using a plastic opening tool, or your finger nails. No excessive force is necessary. For ease of accomplishment, start at the battery compartment.
  3. Sony Cyber-shot DSC-S2100 LCD Replacement: step 3, image 1 of 3 Sony Cyber-shot DSC-S2100 LCD Replacement: step 3, image 2 of 3 Sony Cyber-shot DSC-S2100 LCD Replacement: step 3, image 3 of 3
    • Once the rear case has been removed, the LCD and frame are easily identified.
    • Fold the LCD to the right, away from the frame.
    • Do not try to remove the LCD yet since the ribbon cable is still connected.
    • Remove the three Philips screws from the LCD frame.
  4. Sony Cyber-shot DSC-S2100 LCD Replacement: step 4, image 1 of 3 Sony Cyber-shot DSC-S2100 LCD Replacement: step 4, image 2 of 3 Sony Cyber-shot DSC-S2100 LCD Replacement: step 4, image 3 of 3
    • When the LCD frame is removed, the ribbon cable becomes clearly visible.
    • Flip the LCD to its left side. Open the clip of the connector by moving the black lock to the right.
    • Remove the LCD
  5. Sony Cyber-shot DSC-S2100 LCD Replacement: step 5, image 1 of 1
    • Ensure the screen displayed greets you, once you reassembled your camera
4 other people completed this guide.
oldturkey03
784,117 Reputation
119 Guides authored
Global Fixers Member of Global Fixers
Community
33 Members
555 Guides authored
2 Comments
你在哪里?把相机给你帮我挨可以吗
Jeanne - Reply
请问你是在多伦多附近吗?
Jeanne - Reply
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 53
All Time: 2,488
