Repairing Sanyo dp50747 Plasma TV Fuse - Power Board
User-Contributed Guide
This guide is not managed by iFixit staff.
  • Add Note x
  • x 6
2 year old TV would not power up one day, after doing online research I found out that it could be the a blown internal fuse $.99, or the power board, around $70 on Ebay. Fortunately in my case it was the fuse (ft8ah250vp) that gave up, and after an hour of work, I had it up and running.
first image
Add Note Edit Step 1 — Fuse - Power Board  ¶
  • Step 1 - Remove all 42 screws from back cover. Remove top center screw last, it will help to hold the panel in place during removal of other screws.
first image
Add Note Edit Step 2  ¶
  • WARNING!!! DO NOT TOUCH ANYTHING INSIDE. Even after disconnected from the power outlet, the capacitors are electrical components capable of storing electrical energy. Some can have the same energy as a defibrillator and could easily stop your heart. WARNED!!!
  • There are 5 fuses total, make sure to remove them from the holder and check for continuity with a multimeter.
  • If all test Ok, you might need to have the Power board replaced.
first image
Add Note Edit Step 3  ¶
  • That's the one that I found faulty. Just Remove it with a pair of needle-nose pliers and replace with a new one (ft8ah250vp).
first image
Add Note Edit Step 4  ¶
  • TV up and running... and the best part was that it only cost me less than a dollar to get it repaired!!!!
For more information, check out the Sanyo dp50747 Plasma TV device page.
Did you successfully follow this guide?
This guide has been completed 6 times.
