Repairing Palm Treo 600 Keyboard
User-Contributed Guide
Replace the keyboard!!
Sections
Image #1
Add Note Edit Step 1 — Back Case  ¶
  • On the back of the device, locate the 3 rubber plugs, and use a plastic spudger to remove them.
Image #1 Image #2
Add Note Edit Step 2  ¶
  • Use the T6 Torx Screwdriver to remove all 4 screws.
  • You have to first remove the Stylus to access the 4th screw.
Image #1 Image #2
Add Note Edit Step 3  ¶
  • Using a plastic opening tool, carefully separate the front and back cases.
  • Note: The antenna will detach from the phone.
Image #1 Image #2
Add Note Edit Step 4 — Front Case  ¶
  • Using a T6 Torx Screwdriver, remove the two screws.
  • The motherboard will now be loose from the front case.
Image #1
Add Note Edit Step 5 — Keyboard  ¶
  • Using the spudger, flip open the clasp that holds the data ribbon in place.
Image #1
Add Note Edit Step 6  ¶
  • Pull out the ribbon.
  • The keyboard will disconnect from the phone.
Required Tools
Spudger
$2.95 · 50+ In stock
Plastic Opening Tools
Popular Products
iPad 2 Adhesive Strips
$6.95 · 50+ In stock
iPhone 4S Replacement Battery
$29.95 · 50+ In stock
Metal Spudger
Heavy-duty Spudger
$4.95 · 50+ In stock
T8 Torx Security Bit Screwdriver
