Page 1 of 1
Repairing Nintendo GameCube Optical Drive Assembly
User-Contributed Guide
This guide is not managed by iFixit staff.
Improper Action
This guide contains images that improperly convey how to perform a specific action.
Incorrect Text
This guide contains steps with ambiguous, improper, duplicate, misleading, or off-topic text.
Grammatical Errors
This guide has grammatical errors or does not meet iFixit's writing guidelines.
Incorrect Bullets
This guide contains bullet colors that do not match markup, or improperly-used bullet types.
- Author: mwbisson
- Time required: 30 minutes
- Difficulty: Moderate
This guide will teach you how to disassemble the GameCube Optical Drive Assembly for the purpose of accessing the Optical Drive and the laser.
Sections
- Exterior Case 2 steps
- Front and Back Panel 3 steps
- Optical Drive Assembly 4 steps
- Optical Drive Assembly 8 steps
- View:
- Paginated
- Full width
Edit
Step 6
On the left side of the unit you'll find the cooling fan and its housing. Remove the two (2) Phillips #2 screws holding the cooling fan housing onto the unit.
Do not pull out the cooling fan wire (red and black wire) from the main unit as it will not be necessary to do so.
Edit
Step 8
The optical drive is screwed down to a metal plate.
Unscrew a total of twelve (12) Phillips #2 screws around the outer edge of the optical drive unit metal plate.
There are three (3) screws to the left of the metal plate.
Four (4) screws around the back of the metal plate.
Five (5) screws holding the right side of the metal plate to the Gamecube unit.
Edit
Step 9
Carefully separate the optical drive assembly from the rest of the unit.
The optical drive assembly is secured to the motherboard underneath using a slot. So some force will be needed when lifting the assemble from the motherboard.
The metal plate will still remain attached to the actual optical drive at this point. As shown in picture 3.
This guide has been completed 1 time.
Page 1 of 1
