Repairing Nintendo GameCube Optical Drive Assembly
User-Contributed Guide
This guide is not managed by iFixit staff.
Improper Action
Improper Action
This guide contains images that improperly convey how to perform a specific action.
Incorrect Text
Incorrect Text
This guide contains steps with ambiguous, improper, duplicate, misleading, or off-topic text.
Grammatical Errors
Grammatical Errors
This guide has grammatical errors or does not meet iFixit's writing guidelines.
Incorrect Bullets
Incorrect Bullets
This guide contains bullet colors that do not match markup, or improperly-used bullet types.
  • Author: mwbisson
  • Time required: 30 minutes
  • Difficulty: Moderate
  • Add Note x
This guide will teach you how to disassemble the GameCube Optical Drive Assembly for the purpose of accessing the Optical Drive and the laser.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 1 — Exterior Case  ¶
  • Flip the unit over and locate the four screws shown in the second photograph. Remove the four corner screws located on the bottom of the unit using a 4.5 mm Gamebit screwdriver.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 2  ¶
  • With the GameCube placed upside down, pull the bottom half of the unit away from the top outer casing.
first image
Add Note Edit Step 3 — Front and Back Panel  ¶
  • Depress clips and remove back panel as shown.
Next » « Previous
Required Tools
Phillips #1 Screwdriver
$8.95 · 50+ in stock
Phillips #2 Screwdriver
$4.95 · 28 in stock
Gamebit 4.5mm
$24.95 · 18 in stock
Recommended Tools
Home Tech Toolkit
$24.95 · 50+ in stock
Sorting Tray
$7.95 · 44 in stock
Anti-Static Wrist Strap
$7.95 · 50+ in stock
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$6.95 · 50+ in stock
Popular Products
iPhone 3G and 3GS Mute Button
$4.95 · 50+ in stock
Plastic Opening Tools
$2.95 · 50+ in stock
T6 Torx Screwdriver
54 Bit Driver Kit
T8 Torx Security Bit Screwdriver
$6.95 · 12 in stock
Notes Add Note Notes are offturn on
