Repairing Nintendo GameCube Front and Back Panel
User-Contributed Guide
This guide is not managed by iFixit staff.
  • Author: dcarlin
  • Time required: 5 Minutes
  • Difficulty: Easy
  • Add Note x
Removing these panels allows further access to the GameCube's components.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 1 — Exterior Case  ¶
  • Flip the unit over and locate the four screws shown in the second photograph. Remove the four corner screws located on the bottom of the unit using a 4.5 mm Gamebit screwdriver.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 2  ¶
  • With the GameCube placed upside down, pull the bottom half of the unit away from the top outer casing.
first image
Add Note Edit Step 3 — Front and Back Panel  ¶
  • Depress clips and remove back panel as shown.
first image
Add Note Edit Step 4  ¶
  • Carefully unclip controller ports in the front of the unit.
    • A ribbon cable is still attached to the unit. Do not disconnect this cable (outlined in yellow).
first image
thumb image 1
thumb image 2
Add Note Edit Step 5  ¶
  • Remove the two Phillips #2 screws.
  • Carefully pull gray outer casing from circuit board.
For more information, check out the Nintendo GameCube device page.
Did you successfully follow this guide?
This guide has been completed 0 times.
