Image #1
Add Note Edit Step 17 — Nintendo DS Lite - Not Charging Repair Guide  ¶
  • The EM10 charging filter is located next to the power connector on the motherboard.
  • If the filter is missing or obviously broken, move on to STEP 18
  • Use a multimeter to test the EM10 filter - measure the resistance between each of the yellow solder pads, and then between each of the cyan solder pads. If everything is OK you should have close to 0 Ohms between each set of pads. You should NOT have any connection between the cyan pads and yellow pads. If the filter fails either test it needs to be replaced.
Image #1 Image #2 Image #3
Add Note Edit Step 18  ¶
  • Remove the faulty EM10 filter. Use a soldering iron to melt the solder and gently lift off the filter with tweezers or pliers, being careful not to pull the copper tracks off the motherboard.
  • A replacement EM10 filter is available HERE (as at 01/01/12) no doubt other suppliers exist
  • Solder new EM10 filter into place, ensuring correct orientation. If required, check the new filter with a multimeter to confirm before installing.
  • Alternate method - Bridge the solder pads that correspond with each set of pads - yellow to yellow and cyan to cyan
  • Bypassing the EM10 filter may affect the system performance and is not recommended
Next » « Previous
Required Tools
Spudger
$2.95 · 50+ In stock
Phillips #00 Screwdriver
$4.95 · 50+ In stock
Soldering Station
$24.95 · 13 In stock
Lead-Free Solder
Tri-wing Y1 Screwdriver
$9.95 · 50+ In stock
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 16 In stock
Inspection Scope
$39.95 · 38 In stock
Frictionless Ratchet
$24.95 · 48 In stock
Portable Anti-Static Mat
$24.95 · 16 In stock
Popular Products
T5 Torx Screwdriver
$6.95 · 50+ In stock
Precision Tweezers Set
$4.95 · 37 In stock
iOpener
$14.95 · 50+ In stock
