Repairing Nintendo DS Bottom LCD Screen
Missed a Step
Missed a Step
Oops! This guide is currently missing some important steps.
User-Contributed Guide
Incorrect Tools
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
  • Author: dnguye26
  • Time required: 10 Minutes
  • Difficulty: Easy
After removing the circuit board, the bottom LCD screen can easily be removed from the Nintendo DS.
Image #1 Image #2
  • Remove the cartridge from the console.
  • Use a Phillips #00 Screwdriver to remove the screw securing the battery door to the rear case.
  • Remove the battery door.
Image #1
Add Note Edit Step 2  ¶
  • Use a plastic opening tool or spudger to pry out the battery from the bottom. If a plastic open tool or spudger isn't available, your fingernails may work.
Image #1
Add Note Edit Step 3  ¶
  • Remove the battery from the Nintendo DS.
Image #1
Add Note Edit Step 4 — Back Panel  ¶
  • Remove the 7 tri-wing screws located on the back.
  • It might be helpful to remove the strap from the hole to access the top left screw.
Image #1 Image #2 Image #3
Add Note Edit Step 5  ¶
  • With your hands, pry the back panel off the main case.
  • Separate the back from the front, and set it aside.
Image #1
Add Note Edit Step 6 — Main Circuit Board  ¶
  • Using a Phillips #00 screwdriver, remove the 4 screws on the circuit board.
  • Be careful NOT to slip with the screwdriver, you can damage the circuit board!
Add Note Edit Step 7  ¶
  • Unlock the two large ribbon cables by moving the black clip up.
  • Carefully pull the ribbon cables down and out with your fingers.
  • Do not use pliers to pull the cables, as they can be damaged easily.
Image #1 Image #2
Add Note Edit Step 8  ¶
  • Locate the two small ribbon cables, beneath the rightmost large ribbon cable.
  • Slide the locks for the small ribbon cables down to the side, and remove the cables.
  • It may be useful to use tweezers to remove the small ribbon cables.
  • Be careful not to damage the delicate ribbon cables.
Next » « Previous
Required Tools
$4.95 · 50+ In stock
Tri-wing Y1 Screwdriver
$9.95 · 50+ In stock
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 11 In stock
Inspection Scope
$39.95 · 37 In stock
Frictionless Ratchet
$24.95 · 47 In stock
Portable Anti-Static Mat
$24.95 · 15 In stock
Popular Products
iPad 2 Adhesive Strips
$6.95 · 50+ In stock
iPad 2 Front Panel Assembly
$134.95 · 50+ In stock
iPhone 4S Dock Connector
$34.95 · 50+ In stock
54 Bit Driver Kit
$24.95 · 50+ In stock
Heavy-duty Suction Cups (Pair)
$14.95 · 50+ In stock
