Replacing Nintendo DS Battery
Missed a Step
Missed a Step
Oops! This guide is currently missing some important steps.
User-Contributed Guide
Guide to removing the Nintendo DS battery
  • Author: dnguye26
  • Time required: 1 Minute
  • Difficulty: Very easy
This guide will walk you through removing the Nintendo DS battery.
Image #1 Image #2
  • Remove the cartridge from the console.
  • Use a Phillips #00 Screwdriver to remove the screw securing the battery door to the rear case.
  • Remove the battery door.
Image #1
Add Note Edit Step 2  ¶
  • Use a plastic opening tool or spudger to pry out the battery from the bottom. If a plastic open tool or spudger isn't available, your fingernails may work.
Image #1
Add Note Edit Step 3  ¶
  • Remove the battery from the Nintendo DS.
Required Tools
Spudger
$2.95 · 50+ In stock
$4.95 · 50+ In stock
Plastic Opening Tools
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 31 In stock
Inspection Scope
$39.95 · 40 In stock
Frictionless Ratchet
$24.95 · 49 In stock
Portable Anti-Static Mat
$24.95 · 19 In stock
Popular Products
1.5" Thin Putty Knife
$6.95 · 14 In stock
Metal Spudger Set
$7.95 · 50+ In stock
T8 Torx Security Bit Screwdriver
$6.95 · 50+ In stock
