Repairing Nintendo DS Back Panel
Missed a Step
Missed a Step
Oops! This guide is currently missing some important steps.
User-Contributed Guide
  • Author: dnguye26
  • Time required: 5 Minutes
  • Difficulty: Easy
  • Add Note x
  • x 4
Removing the back panel is simple, provided you have the correct screwdriver. Nintendo uses a special Tri-wing bit for the case, be sure you have one of these before disassembling!
Image #1 Image #2
  • Remove the cartridge from the console.
  • Use a Phillips #00 Screwdriver to remove the screw securing the battery door to the rear case.
  • Remove the battery door.
Image #1
Add Note Edit Step 2  ¶
  • Use a plastic opening tool or spudger to pry out the battery from the bottom. If a plastic open tool or spudger isn't available, your fingernails may work.
Image #1
Add Note Edit Step 3  ¶
  • Remove the battery from the Nintendo DS.
Image #1
Add Note Edit Step 4 — Back Panel  ¶
  • Remove the 7 tri-wing screws located on the back.
  • It might be helpful to remove the strap from the hole to access the top left screw.
Image #1 Image #2 Image #3
Add Note Edit Step 5  ¶
  • With your hands, pry the back panel off the main case.
  • Separate the back from the front, and set it aside.
Required Tools
$4.95 · 50+ In stock
Tri-wing Y1 Screwdriver
$9.95 · 45 In stock
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 27 In stock
Inspection Scope
$39.95 · 40 In stock
Frictionless Ratchet
$24.95 · 49 In stock
Portable Anti-Static Mat
$24.95 · 19 In stock
Popular Products
iPhone 5 Liberation Kit
$9.95 · 25 In stock
T6 Torx Screwdriver
Magnetizer/Demagnetizer
Heat Gun
$24.95 · 25 In stock
iSesamo Opening Tool
$9.95 · 50+ In stock
