Nikon Coolpix L16 LCD screen replacement
  1. Nikon Coolpix L16 LCD screen replacement, LCD: step 1, image 1 of 3 Nikon Coolpix L16 LCD screen replacement, LCD: step 1, image 2 of 3 Nikon Coolpix L16 LCD screen replacement, LCD: step 1, image 3 of 3
    • Clearly visible damage to the LCD. It did not even light up.
    • Remove the screw from the right side.
    • Remove the visible screw from the left side.
  2. Nikon Coolpix L16 LCD screen replacement: step 2, image 1 of 3 Nikon Coolpix L16 LCD screen replacement: step 2, image 2 of 3 Nikon Coolpix L16 LCD screen replacement: step 2, image 3 of 3
    • Open the USB A/C cover, there is one more screw that needs to be removed. That is why it is important to always remove all covers...
    • Remove the three screws from the bottom.
    • Start splitting the case from the battery compartment. I used an opening tool, but fingernails will be sufficient as well.
  3. Nikon Coolpix L16 LCD screen replacement: step 3, image 1 of 3 Nikon Coolpix L16 LCD screen replacement: step 3, image 2 of 3 Nikon Coolpix L16 LCD screen replacement: step 3, image 3 of 3
    • After the splitting of the case, the LCD is imediately visible.
    • Lift the LCD out of the frame by using your fingernail or an opening tool. Do not remove it yet, it is still connected.
    • Flip the black clasp up by using fingernails or the opening tool. No big force is required. Remove the old LCD.
  4. Nikon Coolpix L16 LCD screen replacement: step 4, image 1 of 2 Nikon Coolpix L16 LCD screen replacement: step 4, image 2 of 2
    • Here is the new screen, note the blue tab. This is the screen protector, remove it after installation.
    • Reassemble in reverse order. Hopefully your results will be the same as for me.
oldturkey03
783,787 Reputation
119 Guides authored
Global Fixers Member of Global Fixers
Community
33 Members
551 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 15
All Time: 2,954
