Repairing Motorola Razr V3c Upper Casing (CDMA)
Grammatical Errors
Grammatical Errors
This guide has grammatical errors or does not meet iFixit's writing guidelines.
User-Contributed Guide
This guide is not managed by iFixit staff.
  • Author: krisko
  • Time required: 25 Minutes
  • Difficulty: Difficult
  • Add Note x
This guide will help you replace the upper casing on your device. Following these steps will also enable you to replace the camera.
first image
Add Note Edit Step 1 — Upper Casing (CDMA)  ¶
  • Remove the four rubber pieces from the surrounding area of the inner screen.
first image
Add Note Edit Step 2  ¶
  • Unscrew the screws with the a T4 screwdriver.
first image
Add Note Edit Step 3  ¶
  • Pry the screen open using a plastic spudger,
  • Separate the housing from the screen carefully as the screen and camera are only held on by two ribbons
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 4  ¶
  • Take the screen housing off
  • A few small pieces may fall out during this step, so take care.
For more information, check out the Motorola Razr V3c device page.
Did you successfully follow this guide?
This guide has been completed 1 time.
