Repairing Motorola Razr V3c Screen (CDMA)
Grammatical Errors
Grammatical Errors
This guide has grammatical errors or does not meet iFixit's writing guidelines.
User-Contributed Guide
This guide is not managed by iFixit staff.
  • Add Note x
This guide will show you how to remove and replace the screen for a Motorola V3c.
first image
Add Note Edit Step 1 — Upper Casing (CDMA)  ¶
  • Remove the four rubber pieces from the surrounding area of the inner screen.
first image
Add Note Edit Step 2  ¶
  • Unscrew the screws with the a T4 screwdriver.
first image
Add Note Edit Step 3  ¶
  • Pry the screen open using a plastic spudger,
  • Separate the housing from the screen carefully as the screen and camera are only held on by two ribbons
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 4  ¶
  • Take the screen housing off
  • A few small pieces may fall out during this step, so take care.
first image
thumb image 1
thumb image 2
Add Note Edit Step 5 — Camera (CDMA)  ¶
  • Pry screen cover off with plastic spudger
  • The screen cover has some adhesive holding it to the screen
first image
Add Note Edit Step 6  ¶
  • Remove small black sticker covering the camera ribbon connector
first image
Add Note Edit Step 7  ¶
  • Flip over small hinge that cover the camera ribbon connection
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 8  ¶
  • Pull off the rubber camera cover an camera
  • The camera and camera cover may come off separately or togethel
first image
Add Note Edit Step 9 — Screen (CDMA)  ¶
  • Disconnect the metallic ribbon cover
first image
thumb image 1
thumb image 2
Add Note Edit Step 10  ¶
  • Remove and replace the screen
For more information, check out the Motorola Razr V3c device page.
Did you successfully follow this guide?
This guide has been completed 1 time.
