Remove the battery with your fingers by pulling the battery from the top corners labeled "Pull Here" located on the left and right side of the top of the battery.
To begin detaching the battery dock, unscrew the 4 black screws on each corner of the phone with the T5 Torx Screwdriver.
Lift up the battery dock where the hinges are located. Carefully insert the T5 Torx Screwdriver in between the battery dock and the back plate of the battery. (See the picture to locate the hinges)
Remove the battery dock by popping it up with The Spudger.
Next, turn the frame on it's side and gently tap it till the hinge cover that was screwed in falls out.
Then use your flathead to push here. Be careful! Apply a little force but not too much or else the left hingecover you're pushing out here may shoot out and get lost.
