Repairing Dell Inspiron 1150 Optical drive
User-Contributed Guide
This guide is not managed by iFixit staff.
Incorrect Text
Incorrect Text
This guide contains steps with ambiguous, improper, duplicate, misleading, or off-topic text.
Grammatical Errors
Grammatical Errors
This guide has grammatical errors or does not meet iFixit's writing guidelines.
Improper Action
Improper Action
This guide contains images that improperly convey how to perform a specific action.
The purpose of this guide is to instruct the user on how to remove the Optical Drive in order to replace or correct it.
  • Author: Daniel
  • Time required: 2 minutes
  • Difficulty: Very easy
  • Add Note x
The Optical Drive is your CD or DVD drive. In the event that it becomes damaged or fails to run, you might want to replace it.
first image
thumb image 1
thumb image 2
thumb image 3
  • With the laptop placed upside down, locate the "Battery Release" button. It has a little "Padlock" symbol next to it.
  • Slide the "Battery Release" button toward the padlock symbol and hold it there. Note:- The button is spring loaded and will return if released.
  • Gently extract the battery from the side of the laptop
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 2 — Removing the Top Panel  ¶
  • Tilt the computer screen all the way back until you can easily access the power panel.
  • Use the plastic prying tool to gently pry the panel off.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 3  ¶
  • Next, locate the four Phillips screws on the keyboard and remove the screws using a #00 Phillips screwdriver.
  • Lift the keyboard up and disconnect the white cable underneath to remove the keyboard completely.
Next » « Previous
