Canon EOS 30 LCD Screen Replacement
  1. Canon EOS 30 LCD Screen Replacement, Front Panel: step 1, image 1 of 1
    • Remove the two 4.8 mm black screws above the lens on the front of the camera.
  2. Canon EOS 30 LCD Screen Replacement: step 2, image 1 of 1
    • Remove the 4.3 mm black screw under the lens ring, and the 4.8 mm black screw under the camera.
  3. Canon EOS 30 LCD Screen Replacement: step 3, image 1 of 1
    • Remove the 4.8 mm black screw on the left side of the camera.
  4. Canon EOS 30 LCD Screen Replacement: step 4, image 1 of 1
    • Remove the front panel by lifting it away from the camera's body.
  5. Canon EOS 30 LCD Screen Replacement, Top Panel: step 5, image 1 of 1
    • Slide the outer eyepiece upward to remove it.
  6. Canon EOS 30 LCD Screen Replacement: step 6, image 1 of 1
    • Remove the two 4.75 mm black screws located on the top of the camera.
  7. Canon EOS 30 LCD Screen Replacement: step 7, image 1 of 1
    • Remove the four 4.3 mm black screws near the bottom corners of the eyepiece at the back of the camera.
  8. Canon EOS 30 LCD Screen Replacement: step 8, image 1 of 2 Canon EOS 30 LCD Screen Replacement: step 8, image 2 of 2
    • Slowly separate the top panel from the camera by pushing it upward.
    • Separating the top panel too far or quickly can damage the ribbon cable and connecting wires that are still attached to the top panel of the camera.
  9. Canon EOS 30 LCD Screen Replacement, LCD Screen: step 9, image 1 of 1
    • To unclip gold connector push the edge up and away from the lcd screen. A plastic opening tool is recommended.
    • The gold connector can fall into the camera, but it will remain attached and can be pulled back up.
  10. Canon EOS 30 LCD Screen Replacement: step 10, image 1 of 1
    • Lift LCD screen out of mount.
2 other people completed this guide.
Sterling Vinson
259 Reputation
5 Guides authored
Cal Poly, Team 8-8, Regan Spring 2011 Member of Cal Poly, Team 8-8, Regan Spring 2011
CPSU-REGAN-S11S8G8
5 Members
22 Guides authored
2 Comments
Thank's , your tutorial nice ... gracias
fajar - Reply
Where do you find replacement lcd screen if the one on the camera is cracked?
Jasmine - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 17
All Time: 5,276
