Image #1
Add Note Edit Step 9  ¶
  • Now remove the logic board & LCD assembly from the rear housing. Be gentle, and do not use excessive force.
Image #1 Image #2
Add Note Edit Step 10  ¶
  • Flip the logicboard around so that it is sitting on top of the screen, now remove the two ribbon cables for the LCD & Digitizer.
Image #1
Add Note Edit Step 11  ¶
  • Put your broken assembly to the side, and now install your new one following the past steps in reverse.
  • ONE THING TO KEEP IN MIND WHEN ORDERING YOUR NEW PART, LOOK ON THE RIBBON CABLE FOR ETHER V.014 or V.024 . (Shown in blue)
Next » « Previous
Required Tools
T6 Torx Screwdriver
$4.95 · 50+ In stock
Plastic Opening Tools
$2.95 · 50+ In stock
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 19 In stock
Inspection Scope
$39.95 · 38 In stock
Frictionless Ratchet
$24.95 · 48 In stock
Portable Anti-Static Mat
$24.95 · 16 In stock
Popular Products
Metal Spudger
Metal Spudger Set
$7.95 · 50+ In stock
T5 Torx Screwdriver
$6.95 · 50+ In stock
T10 Torx Security Bit Screwdriver
