Repairing Apple TV 1st Generation Power Light
User-Contributed Guide
This guide is not managed by iFixit staff.
Incorrect Bullets
Incorrect Bullets
This guide contains bullet colors that do not match markup, or improperly-used bullet types.
Incorrect Text
Incorrect Text
This guide contains steps with ambiguous, improper, duplicate, misleading, or off-topic text.
Unsatisfactory Images
This guide has low-quality images. Pictures need to be either re-edited or re-taken.
Markup Problems
Markup Problems
This guide has markup that is either not properly set or is missing from some images.
Unnecessary Steps
Unnecessary Steps
This guide contains steps that are not necessary.
Many Apple TV forums report a weakening or dimming of the white power indicator. This is due to premature failure of a white LED. It is possible to replace the LED and restore the power light.
  • Author: John Matheson
  • Time required: 1 Hour
  • Difficulty: Very difficult
  • Add Note x
This repair requires either an extremely fine tipped soldering iron and extremely steady hands, or an SMD rework station.
Sections
Tools
Relevant parts
first image
Add Note Edit Step 1 — Logic Board  ¶
  • Remove the T8 Torx screw securing the metal shield to the case.
  • In order to remove the T8 screw, you must insert the screwdriver through the access hole in the metal shield, located near the PRAM battery.
first image
thumb image 1
thumb image 2
Add Note Edit Step 2  ¶
  • Remove the T20 screw securing the metal shield to the case, located near the digital audio port.
  • Lift and remove the metal shield away from the upper case of the Apple TV.
first image
Add Note Edit Step 3  ¶
  • Use a pair of tweezers to pull the IR cable straight away from its socket on the logic board.
  • Make sure to pull the connector parallel to the face of the logic board, not straight up from its socket.
Next » « Previous
