Repairing a Broken or Loose Paper Towel Hanger
  1. Repairing a Broken or Loose Paper Towel Hanger, Repairing a Broken or Loose Paper Towel Hanger: step 1, image 1 of 1
    • Detach the paper towel hanger from where it is attached.
    • Place it on a flat surface under sufficient light.
  2. Repairing a Broken or Loose Paper Towel Hanger: step 2, image 1 of 3 Repairing a Broken or Loose Paper Towel Hanger: step 2, image 2 of 3 Repairing a Broken or Loose Paper Towel Hanger: step 2, image 3 of 3
    • Inspect the paper towel hanger for loose components.
    • Identify the screw that is making the paper towel loose.
  3. Repairing a Broken or Loose Paper Towel Hanger: step 3, image 1 of 3 Repairing a Broken or Loose Paper Towel Hanger: step 3, image 2 of 3 Repairing a Broken or Loose Paper Towel Hanger: step 3, image 3 of 3
    • Take a screwdriver with a flat head to remove the loose screw.
    • Insert the screwdriver into the loose screw and rotate anti-clockwise to remove the loose screw.
  4. Repairing a Broken or Loose Paper Towel Hanger: step 4, image 1 of 3 Repairing a Broken or Loose Paper Towel Hanger: step 4, image 2 of 3 Repairing a Broken or Loose Paper Towel Hanger: step 4, image 3 of 3
    • Get a replacement screw of the same size and insert it into the area where the old screw was.
    • Line both parts of the paper towel hanger up and secure the new screw with the 3 mm Flathead screwdriver until it's snug.
  5. Repairing a Broken or Loose Paper Towel Hanger: step 5, image 1 of 3 Repairing a Broken or Loose Paper Towel Hanger: step 5, image 2 of 3 Repairing a Broken or Loose Paper Towel Hanger: step 5, image 3 of 3
    • Check to see if the paper towel hanger is now firm and secure.
    • Reattach the paper towel hanger to the wall.
In conclusion, this 'Paper Towel Hanger Repair Guide' empowers you to address a common household issue efficiently and safely. By following these steps and using the recommended tools, you can restore your hanger's functionality and ensure peace of mind.
Nziza Ngango
121 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 23
All Time: 105
