Repairing Starbucks Barista Portafilter
Student-Created Guide
An awesome student from our education program made this guide. It is not managed by iFixit staff.
How to troubleshoot and repair the portafilter.
  • Author: David
  • Difficulty: Moderate
The portafilter pressurizes the water through the coffee filter to produce the espresso. If the portafilter is dirty or malfunctioning it could result in weak coffee, or no coffee at all. This guide will help you disassemble, clean and reassemble your portafilter.
Image #1
Edit Step 1 Portafilter  ¶
  • Turn the portafilter handle to the left to remove it from the machine.
  • Flip the portafilter over so the bottom with the 3 screws faces up.
Image #1
Edit Step 2  ¶
  • Before beginning, make a small, neat "scribe" mark on both the bottom edge of the plastic basket and, right next to it, the top of the metal basket. This match-marks these two pieces. Unscrew and remove the 3 phillips-head screws.
  • Lift off the plastic handle assembly, exposing the internal pressure system and two springs. Take note of the handle's orientation in relation to the metal piece as it will need to be re-attached in exactly the same position to function correctly.
Image #1
Edit Step 3  ¶
  • Take note of the spring's placement, then carefully remove and set them aside.
  • Clean the pressure assembly with a citrus-based cleaner and a brush, making sure to get under the hinged needle valve. Rinse well, then replace the springs.
  • Reattach the handle assembly with the 3 phillips-head screws. If assembled correctly the handle should pivot slightly in relation to the metal portion, than spring back when released.
For more information, check out the Starbucks Barista device page.
Required Tools
Phillips #2 Screwdriver
$4.95 · 13 In stock
Recommended Tools
Universal Drive Adapter
$29.95 · 50+ In stock
iFixit Lock Pick Set
Inspection Scope
$39.95 · 50+ In stock
Frictionless Ratchet
$24.95 · 50+ In stock
Portable Anti-Static Mat
$34.95 · 43 In stock
Popular Products
iPhone 4S Dock Connector
$34.95 · 50+ In stock
iPhone 5 Power and Lock Button
$4.95 · 50+ In stock
Phillips #00 Screwdriver
Magnetic Pickup Tool
Comments Comments are onturn off
Are there any pictures to show how to replace the gasket on the portafilter?
Scott, · Reply
Today: 10
This Week: 58
This Month: 198
All Time: 13,133
