Shure SM58 XLR Connector Replacement
  1. Shure SM58 XLR Connector Replacement, Connector: step 1, image 1 of 3 Shure SM58 XLR Connector Replacement, Connector: step 1, image 2 of 3 Shure SM58 XLR Connector Replacement, Connector: step 1, image 3 of 3
    • While holding the microphone connector in one hand, and the XLR cable in the other hand, slowly pull them apart.
    • Make sure you are not holding the microphone connector by the wires.
    • Check to make sure all of the internal wires are connected. If you see a disconnected wire, take a look at the connector soldering guide.
  2. Shure SM58 XLR Connector Replacement: step 2, image 1 of 2 Shure SM58 XLR Connector Replacement: step 2, image 2 of 2
    • Hold the microphone connector in one hand and the microphone base in the other.
    • Line up the screw in the connector with the hole in the middle of the microphone.
    • Also, align the ridge on the microphone connector (located near the top of the connector) with the slot in the base of the microphone.
  3. Shure SM58 XLR Connector Replacement: step 3, image 1 of 2 Shure SM58 XLR Connector Replacement: step 3, image 2 of 2
    • With those parts aligned, push the connector back into the microphone until the screw lines up with hole in the side of the microphone.
    • Do not push the microphone past this point or the connector may become stuck.
  4. Shure SM58 XLR Connector Replacement: step 4, image 1 of 1
    • Using a small flat head screw driver, turn the screw in the side of the microphone clockwise until it is tight.
Following these steps should reinstall the XLR connector back into the microphone.
2 other people completed this guide.
nat coll
642 Reputation
14 Guides authored
Cal Poly, Team 7-53, Forte Fall 2012 Member of Cal Poly, Team 7-53, Forte Fall 2012
CPSU-FORTE-F12S7G53
5 Members
20 Guides authored
2 Comments
simple clear and precise. Small problem fixed in no time, thank you very much!
Kimmo Pekari - Reply
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 82
All Time: 17,272
